Waring 51BL29 Motor Replacement
  1. Waring 51BL29 Motor Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waring 51BL29 Motor Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom panel.
  3. Waring 51BL29 Motor Replacement, Drive Coupling: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Motor Replacement, Motor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waring 51BL29 Motor Replacement, Motor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waring 51BL29 Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waring 51BL29 Motor Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
Dean Becker
crwdns2935283:004/17/17crwdne2935283:0
485 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G4, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S15-G4, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S15G4
Hi
Where do I source a replacement motor? I have been looking without success for UK supplier. Thanks Jill
I have a much loved Vintage Waring blender …
Jill Lancaster - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 3,393
