Waring 51BL29 Drive Coupling Replacement
  1. Waring 51BL29 Drive Coupling Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waring 51BL29 Drive Coupling Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Drive Coupling Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom panel.
  3. Waring 51BL29 Drive Coupling Replacement, Drive Coupling: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Drive Coupling Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Drive Coupling Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
    THANK YOU!
    THANK YOU!
    THANK YOU!
    I have a Model SDM50. A lot of online instructions address that screw/bolt but mine, like yours, and unlike the models for many of the instructions, cannot be accessed without removing the plate. The part came with absolutely no hint on how to install it. Waring should pay you and utilize your instructions at its website.
    Robert Burns - crwdns2934203:0crwdne2934203:0
Dean Becker
crwdns2935283:004/17/17crwdne2935283:0
470 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G4, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S15-G4, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S15G4
Do you happen to know where I can purchase this replacement part?
Jessica Dye - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 8,222
