Waring 51BL29 Drive Coupling Replacement
    1. Waring 51BL29 Drive Coupling Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waring 51BL29 Drive Coupling Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the blender on its side so the bottom panel is facing you.
      • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
      • Unscrew the 3 screws in the rubber holes.
    2. Waring 51BL29 Drive Coupling Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the bottom panel.
    1. Waring 51BL29 Drive Coupling Replacement, Drive Coupling: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the screwdriver in the head of the middle flat-head screw.
    2. Waring 51BL29 Drive Coupling Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
      • This screw may be reverse-threaded.
    3. Waring 51BL29 Drive Coupling Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
crwdns2935229:05crwdne2935229:0
Dean Becker
crwdns2935283:004/17/17crwdne2935283:0
485 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G4, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S15-G4, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S15G4
Do you happen to know where I can purchase this replacement part?
Jessica Dye - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 9,161
