Many depend on walkers to live their daily lives and continued use can wear down brake cables.
Locate the wire cap near the brake at the bottom of the wheel
Use a set of pliers to remove the wire cap.
Locate the screw that fastens the wire to the brake shoe.
Use the Phillips (PZ2) Head screwdriver to unscrew the fastening bolt and nut.
Use pliers or wrench to undo nut that secures the wire to the body of the walker
Thread the cable wire through the unfastened brake loop and nut.
Unhook the spring connecting the brake shoe to the wheel.
Unscrew the loose bolt and wire from the body and remove by threading it through the wire.
Thread the cable through the white collar halfway up the body of the walker.
Pull the cable sleeve off the cable to expose the metal wires.
Follow the wire up to the opposite end of the wire that attaches to the brake handle.
Use pliers to unfasten the bolt from the plastic handle.
Pull the lower handle out of the plastic casing.
No puedo sacar el mango inferior de carcasa como lo hago?
Por dónde desensamblo?
Salió una ruedita del interior como se coloca con el chicote de freno
Locate the plastic wire anchor cap and use a pair of pliers to remove the cap.
Use the hammer to dislodge the wire anchor.
Completely remove brake handle and wire by threading through the plastic covering
The brake cable listed in these instructions is in fact 1.6 mm dia, which is a standard bicycle brake cable, although I’m not sure what kind of bullet it has on the end. So you could also get this at a bike shop.
The brake cable housing is more complicated. Length is 35 inches to the shoulder of the bushing on one end to the shoulder of the bushing on the other end. The outside diameter of the housing is 6.0 mm. Standard bicycle brake cable housings are 4.0 or 5.0 mm in diameter, and their bushings have simple flat ends without shoulders. Thus, it appears that you cannot buy this part at a bike shop. But it looks like they are available from here:
http://www.spinlife.com/critpath/match.c...
or here:
http://www.phc-online.com/Brake_Cable_Co...
I recommend putting additional cable ties on the brake cables, especially if the walker is frequently plopped in and out of a car. They tend to catch on things and get bent out of shape.
How do you replace a broken hand brake on a rollator walker how do you get the hand grip off
Hi guys,
Thanks for the advice, it helped a lot. I think the biggest risk is getting a cable that is too thick. The existing one on my Mum’s ‘appears‘ to just be a bit smaller than 1.5mm, so I found this 1.4mm cable on eBay. 2 cables for $5.50 including postage.
https://www.ebay.com.au/itm/193828834770
Installed it and it worked a treat. If this seller is no loner around, you want to search for 1.4mm brake cable and make sure the ‘block‘ at the end looks the same.
I have seen the exact same cable selling at ‘Specialist‘ websites for $25.00 each - such a rip off. Just taking advantage of our older people.
how does the cable weave in around the handle rollers
