crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Waka Waka Power Pluscrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Waka Waka Power Plus Teardown, Unboxing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waka Waka Power Plus Teardown, Unboxing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waka Waka Power Plus Teardown, Unboxing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It's not just a box, it's also a use guide.
  2. Waka Waka Power Plus Teardown, Undo the screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waka Waka Power Plus Teardown, Undo the screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waka Waka Power Plus Teardown, Undo the screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The Phillips screws are hidden underneath silicone covers.
  3. Waka Waka Power Plus Teardown, Pry it open and remove the front cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waka Waka Power Plus Teardown, Pry it open and remove the front cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The cover is a pain to get open. The amount of force needed is quite high.
    • The hinges are spring loaded. They tend to fly away when tension is relieved.
  4. Waka Waka Power Plus Teardown, Remove the flip cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waka Waka Power Plus Teardown, Remove the flip cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • As said in the previous step, the springs tend to fly away!
  5. Waka Waka Power Plus Teardown, Remove the light conductor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This can simply be pulled out once the covers are removed.
  6. Waka Waka Power Plus Teardown, Pry out the button: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waka Waka Power Plus Teardown, Pry out the button: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waka Waka Power Plus Teardown, Pry out the button: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A screwdriver may not be the ideal tool for this job, a less sharp object might be better to avoid damage to the silicone.
  7. Waka Waka Power Plus Teardown, Remove the lenses: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat side of the screwdriver to avoid damage to the lens.
  8. Waka Waka Power Plus Teardown, Remove the hinges: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waka Waka Power Plus Teardown, Remove the hinges: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You will stab yourself with the screwdriver while doing this.
    • The white parts of the hinges will very happily fly away and get lost.
  9. Waka Waka Power Plus Teardown, Remove the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waka Waka Power Plus Teardown, Remove the battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waka Waka Power Plus Teardown, Remove the battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out the connector, be careful and only pull the connector and not the wires to avoid damaging them in the process.
    • The battery is fixed in place with double sided tape. Make sure not to bend and damage the battery when taking it out.
    • Text on the battery:
    • Grand-Pro
    • - PL805050 3.7V 8.14Wh
    • GB-GP004 UN38.3 2200mAh
    • + 11-22-2014-11265
  10. Waka Waka Power Plus Teardown, Remove the PCB: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Waka Waka Power Plus Teardown, Remove the PCB: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Waka Waka Power Plus Teardown, Remove the PCB: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two plastic pins holding the PCB in place. You will have to break them.
    • Undo the connection between the PCB and the solar panel with a soldering iron. Do not pull the cables out, this may result in severe damage to the cables or PCB.
    • Top tip: for one time at least, you can redo the plastic pins holding the PCB by pressing a semi-hot soldering iron on the plastic.
  11. Waka Waka Power Plus Teardown, PCBA: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waka Waka Power Plus Teardown, PCBA: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Most important silicon:
    • Texas instruments LM358 Dual opamp
    • Fairchild Semiconductors MJD210 PNP Transistor
    • NXP 74HC595 8Bit shift register
    • Intivation SNBST3 MPPT Solar charger with integrated MCU (heart of the Waka Waka)
    • Dsunsolar High efficiency PET film solar panel. Custom made for Intivation.
  12. Waka Waka Power Plus Teardown, Pry out the solar panel: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Waka Waka Power Plus Teardown, Pry out the solar panel: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flat object like a bank card to avoid bending the solar panel.
    • This Waka Waka has been opened up previously to this teardown. Since the solar panel was originally glued in place, the solar panel was re-attached using double sided tape. When putting your Waka Waka back together, you could either choose glue or double sided tape. Both work fine.
Harm
crwdns2935283:002/09/15crwdne2935283:0
179 crwdns2915208:0crwdne2915208:0
Hallo Harm. Geweldig om je documentatie te vinden.
Per abuis de scharnierende klepstandaard los getrokken. Maar het lukt me niet om die weer terug te duwen.Puzzle. Uitsparingen moeten in elkaar vallen? Zou het liefst natuurlijk de boel niet demonteren.
Gebruik m ook op m'n racefiets .
Graag advies.
Groeten Karel
Karel Slot - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,253
