Use this guide to replace the power switch on your device.
Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
Unscrew the two black 5.556 mm Phillip head screw on the power switch with a Phillips #0 Screwdriver.
Shimmy the power switch off the mount until it is completely removed.
Hello Mrs/ms Swearengin, I’m disassembled my Wahl desingner I’m unable to make the power switch stiff . It’s very loose I can’t recall which screw goes in between two black 5.556 mm Phillip head screw or if it needs a screw at all
