In this guide you will learn how to replace the chip set in a Wahl Lithium Ion Trimmer.
Begin by removing the rubber grip along the handle.
Remove the screws from the top to take the metal piece and plastic part off.
Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
Remove the motor, battery, and motherboard from the plastic casing.
Remove the white plastic piece and the wires from the motherboard.
Remove the old motherboard and install the new one. Then, connect the wires and white piece to the new motherboard.
