Cord problems are bound to eventually happen due to normal use, winding up the cord, and cramming it into a drawer. The cord replacement process is straight forward, but the most important part to remember is do not work on device while it is plugged in. It is also advisable to take advantage of the open device by cleaning out any visible debris.
Unscrew the three 12mm black JIS screw found on the red side of the the device with a JIS #1 driver.
Grab the red cover by the side and lift off the top piece.
Unscrew the 5.556mm screw with a JIS #0 screwdriver. (Black Screw located at power switch)
crwdns2935267:0crwdne2935267:0Spudger$2.99
Insert the metal spudger between the wire connector and the device connector. The spudger should disengage a tension-like lock between both connectors, and once disengaged gently pry out the cord connection.
Remove the cord from the fixed position.
To reassemble your device, follow these instructions in reverse order. When installing new cord, make sure black wire is underneath the white wire.
