Wacom Intuos4 Motherboard Replacement
  1. Wacom Intuos4 Motherboard Replacement, Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos4 Motherboard Replacement, Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos4 Motherboard Replacement, Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos4 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos4 Motherboard Replacement, Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, remove the yellow tape covering the three cable connectors.
  4. Wacom Intuos4 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos4 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the black plastic clip holding the flat wire to the connector with either tweezers or an iFixit opening tool.
    • Pull on the white plastic tab to disconnect the flat wire.
  5. Wacom Intuos4 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos4 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the motherboard from the casing.
    • If you're having trouble, don't force it. Make sure all cables are disconnected and all screws are removed.
Jack Palmgren
crwdns2935283:010/26/22crwdne2935283:0
234 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-6, Botvin Fall 2022 crwdns2935289:0UMass Dartmouth, Team 3-6, Botvin Fall 2022crwdne2935289:0
UMASSD-BOTVIN-F22S3G6
crwdns2942667:0crwdne2942667:0 492
