Wacom Intuos4 Foam Safety Pad Replacement
  1. Wacom Intuos4 Foam Safety Pad Replacement, Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos4 Foam Safety Pad Replacement, Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos4 Foam Safety Pad Replacement, Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Foam Safety Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos4 Foam Safety Pad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Foam Safety Pad Replacement, Foam Safety Pad: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to safely remove the white and sliver pad without applying enough pressure to scratch the motherboard.
Aidan Sullivan
crwdns2935283:010/26/22crwdne2935283:0
293 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-6, Botvin Fall 2022 crwdns2935289:0UMass Dartmouth, Team 3-6, Botvin Fall 2022crwdne2935289:0
UMASSD-BOTVIN-F22S3G6
crwdns2942667:0crwdne2942667:0 235
