Wacom Intuos Pro Touch Pad Replacement
  1. Wacom Intuos Pro Touch Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the device so the bottom casing is facing upwards.
    • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
  2. Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
    • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
  3. Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
    • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
    • While going around the edges, make sure you have a tight grip to keep the device from sliding.
  4. Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
  5. Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If not already done, desolder the three colored cables that connect the battery to the motherboard.
    • After desoldering the battery, carefully remove it.
    • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
    • For help soldering, check out our How to Solder and Desolder Connections guide.
  6. Wacom Intuos Pro Touch Pad Replacement, Touch Pad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the blue tabs on the four ribbon cables from the ZIF connectors on the motherboard.
  7. Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 4.5mm screws using a Phillips #00 screwdriver.
  8. Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently wedge the Jimmy under the black backing of the blue touchpad.
    • Gently pry up the touchpad and remove it from the case.
Madison Winebrenner
crwdns2935283:009/20/21crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team 2-13, Eggleston Fall 2021 crwdns2935289:0The Citadel Military College of South Carolina, Team 2-13, Eggleston Fall 2021crwdne2935289:0
CMCSC-EGGLESTON-F21S2G13
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 1,866
