Wacom Intuos Pro Touch Pad Replacement
    1. Wacom Intuos Pro Touch Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Orient the device so the bottom casing is facing upwards.
      • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
    2. Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
      • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
    3. Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
      • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
      • While going around the edges, make sure you have a tight grip to keep the device from sliding.
    4. Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
    5. Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos Pro Touch Pad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • If not already done, desolder the three colored cables that connect the battery to the motherboard.
      • After desoldering the battery, carefully remove it.
      • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
      • For help soldering, check out our How to Solder and Desolder Connections guide.
Luis Alva
crwdns2935283:001/15/20crwdne2935283:0
253 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S6-G3, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S6-G3, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S6G3
crwdns2935297:036crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,109
