Wacom Intuos CTL4100 Battery Replacement
  1. Wacom Intuos CTL4100 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the tablet over so the bottom case faces upwards.
    • Remove the rubber pads on the corners by pulling them up with your fingers.
  2. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  3. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening pick between the front and back case to unclip the clips that hold the cases together.
    • Slide your plastic opening pick around the sides until all clips are unclipped.
  4. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom case to separate the top and bottom case
    • When you see the internal components, set aside the bottom case.
  5. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the yellow tape that is on top of the battery wires.
    • When the battery wires under the tape are exposed, stick the yellow tape just above the battery wires.
  6. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up the battery wire pin with your fingers to disconnect the pin from the motherboard.
  7. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by lifting the battery up with your fingers.
  8. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the new battery on the area you removed the battery.
  9. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently connect the battery wire pin to the motherboard.
  10. Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom Intuos CTL4100 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reapply the tape you put above the battery wires.
To reassemble your device, follow step 4 in reverse order.
crwdns2935229:05crwdne2935229:0
Marcus Sisouphanh
crwdns2935283:009/11/21crwdne2935283:0
316 crwdns2915208:0crwdne2915208:0
York University, Team 1-24, O'Regan Fall 2021 crwdns2935289:0York University, Team 1-24, O'Regan Fall 2021crwdne2935289:0
YORK-O'REGAN-F21S1G24
crwdns2947412:05crwdne2947412:0
Where did you get the replacement battery?
David VeLar - crwdns2934203:0crwdne2934203:0
Will it work without a battery?
Jordi Prats - crwdns2934203:0crwdne2934203:0
Answering my own question, yes, it works without a battery. It will popup a notification of low battery sometimes, and obviously it won't work wirelessly.
Ah, and I tried this with a CTL6100 tablet, so this guide is valid for this model as well (a bit larger but mostly identical inside).
Jordi Prats -
Where did you get the battery pls?
Taaa - crwdns2934203:0crwdne2934203:0
I can probably say Aliexpress would be your best bet.
Gabriel Smirnov -
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 166
crwdns2942667:0crwdne2942667:0 4,741
