Wacom DTU-1031X Disassembly
  1. Wacom DTU-1031X Disassembly, Wacom DTU-1031X Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the tablet with the screen facing down the surface.
    • (Optional) Remove the plastic dummy plug in the pen holder
  2. Wacom DTU-1031X Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom DTU-1031X Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 4 rubber feet
    • Unscrew 4 Phillips #0screws
  3. Wacom DTU-1031X Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom DTU-1031X Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip the bottom casing
    • The clips are very strong and require substantial amount of force to unclip
    • The easiest start point to start prying is around the USB port
    • See the second image to locate the position of the clips
  4. Wacom DTU-1031X Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom DTU-1031X Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom DTU-1031X Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the USB daughter board, unscrew 3 Philips #00 screws
    • One of the screws are hiding under the tape
    • Disconnect the cable and remove the board
  5. Wacom DTU-1031X Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom DTU-1031X Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom DTU-1031X Disassembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the mainboard, unscrew 4 Phillips #00 screws
    • Removal of the yellow kapton tape will be required
    • Unplug the 40-pin LVDS flex cable
    • The transparent tape holding the 40-pin LVDS cable to the mainboard is a part of the cable, and should not be separated
    • Unplug two cables connecting the digitizer daughter board to mainboard
    • Unplug the USB daughter board cable
  6. Wacom DTU-1031X Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom DTU-1031X Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom DTU-1031X Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the digitizer daughter board, unscrew 4 Phillips #00 screws
    • Unclip two flex cables connecting the digitizer to the digitizer board
    • Unclipped connector will have it's black plastic part facing up
    • Disconnect two cables connecting the daugher board with the mainboard
  7. Wacom DTU-1031X Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacom DTU-1031X Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the 40-pin LVDS cable from the LCD display
    • Unscrew 11 Phillips #00 screws holding the metal piece to the front plastic casing
  8. Wacom DTU-1031X Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacom DTU-1031X Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacom DTU-1031X Disassembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew 9 wide Phillips #00 screws holding the LCD panel to the front plastic casing
    • One of the screws is hiding under the metalic tape
    • The LCD display will now be loose, and can be removed
    • The front glass is glued to the front plastic casing
00004707
crwdns2935283:007/23/20crwdne2935283:0
1,097 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 290
