Wacom Cintiq 24HD Power Supply Replacement
  1. Wacom Cintiq 24HD Power Supply Replacement, Power Supply: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Procurement of a suitable commercially available power pack.
    • Type GST120A24R7B
    • R7B is important as this is the only connector that fits the Wacom tablet. (Connector type KYCON KPPX-4).
    • Performance data 120W, 24 volts
    • The power pack opens. To do this, the four rubber plugs are removed and the four screws are removed with a Phillips screwdriver. The housing can then be easily removed.
    • The 24V side has four wires: black, blue, red and white. These are soldered and can be removed.
    • The black and blue wire is soldered to the minus output (V-). The red and white wire is soldered to the 24V (V+) output. Note: The black wire is connected to the metal body of the plug.
    • The power supply will reassemble and can now be connected to the Wacom Tablet.
    • Test: According to the assignment in the picture, after resoldering the lines, the ground line must be on the upper 2 pins and the +24V voltage on the lower 2 pins
Work the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0HelloMacOScrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Wilfried Weigelt
crwdns2935283:002/29/20crwdne2935283:0
85 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 1,631
