Wacom CTH-460 Bamboo Pen & Touch is a fairly easy device to disassemble, requiring only a Phillips #000 screwdriver and tweezers or similar tool to pry adhered and clipped elements.
The only fragile elements are flex cables connecting the touch digitizer to the mainboard.
If you plan on replacing the USB cable, please note that the USB cable is soldered to the mainboard.
Place the device facing bottom part up.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove 4 rubber feet using a spudger or a pair of tweezers
Unscrew 4 #000 Phillips screws
Use spudger or other prying tool to open the tablet.
The clips are located all around the perimeter of the tablet
While the pen holder might seem permamently riveted, it can be removed and cleaned
The mainboard is now loose and can be removed.
