Wacker Pump PT3A 2012 Impeller Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Wacker Pump PT3A 2012 Impeller Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacker Pump PT3A 2012 Impeller Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the device is switched off and the engine is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Pump PT3A 2012 Impeller Replacement, Remove the pump housing cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Pump PT3A 2012 Impeller Replacement, Remove the pump housing cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Pump PT3A 2012 Impeller Replacement, Remove the pump housing cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the included wrench to loosen the four black knobs securing the pump housing cover.
    • If the wrench is missing, slide a screwdriver shank through the knob and twist to loosen the knobs.
  3. Wacker Pump PT3A 2012 Impeller Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Pump PT3A 2012 Impeller Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Pump PT3A 2012 Impeller Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pump housing cover out of the pump and remove it.
  4. Wacker Pump PT3A 2012 Impeller Replacement, Remove the recoil starter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 10 mm socket and wrench to remove the three bolts securing the recoil starter.
  5. Wacker Pump PT3A 2012 Impeller Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacker Pump PT3A 2012 Impeller Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the recoil starter from the engine.
  6. Wacker Pump PT3A 2012 Impeller Replacement, Brace the driveline: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide a large screwdriver through the slots in the starter cap and brace the screwdriver with a wooden block to prevent the driveline from turning clockwise.
  7. Wacker Pump PT3A 2012 Impeller Replacement, Remove the impeller: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacker Pump PT3A 2012 Impeller Replacement, Remove the impeller: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 19 mm socket, extension, and wrench to loosen the impeller from the driveline.
  8. Wacker Pump PT3A 2012 Impeller Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacker Pump PT3A 2012 Impeller Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the impeller from the driveline.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
296 465 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 011crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 63
