Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement
  1. Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Disconnect the spark plug wire: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure the device is switched off and the engine is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the pump housing cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the pump housing cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the pump housing cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the included wrench to loosen the four black knobs securing the pump housing cover.
    • If the wrench is missing, slide a screwdriver shank through the knob and twist to loosen the knobs.
  3. Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pump housing cover out of the pump and remove it.
  4. Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the O-rings: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the O-rings: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Pump PT3A 2012 Housing Cover O-Rings Replacement, Remove the O-rings: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to peel off and remove the two O-rings from the pump housing cover.
    • The two O-rings are different: the top O-ring is slightly thinner than the bottom O-ring.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
296,471 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,011crwdne2935297:0
crwdns2942667:0crwdne2942667:0 697
