Prerequisite only! This procedure is part of another guide and is not meant to be used alone.
Use this guide to remove the air box on a Wacker PG1 (2014) Pump.
Before beginning repairs, disconnect and remove all hoses.
Flip the motor ignition switch into the OFF position.
Use a 4 mm hex key to remove the bolt securing the engine cover.
Use your fingers to pinch the locking tab on the top of the air box cover.
Tilt the unlocked air cleaner cover down and pull it away from the air box to unhook it.
Remove the air box cover.
Use a 6 mm socket to remove the two nuts securing the air box.
Pull the air box directly away from the motor to remove it.
