Wacker Concrete Vibrator M1500120 REV 100 2016 Switch Replacement
  1. Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Disconnect the flex shaft: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Disconnect the flex shaft: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Disconnect the flex shaft: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting, ensure the device is unplugged from power.
    • Pull up on the quick-disconnect handle to release the lock on the flex shaft.
    • Remove the flex shaft.
  2. Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Remove the housing screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T20 Torx screwdriver to remove the nineteen screws securing the two halves of the device housing.
  3. Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Remove the dust filter: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Remove the dust filter: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the device down onto its right side, screw holes facing up.
    • Remove the rear dust filter.
  4. Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Separate the halves: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Separate the halves: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Separate the halves: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift to remove the left half of the device housing.
    • If the housings feel stuck together, use a flathead screwdriver to create a gap between the halves.
  5. Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Lift up the switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Lift up the switch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the switch out of its recess in the case housing.
  6. Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Disconnect the power wires: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Disconnect the power wires: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Disconnect the power wires: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of needle nose pliers to disconnect the black and white power wires from their terminals on the switch.
  7. Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement, Remove the wires from the switch: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 Torx screwdriver to loosen the two terminal screws securing the wires to the switch.
  8. Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull to remove both black wires from their terminals on the switch.
    • During reassembly, install the black wire with text into the 1 terminal, and the black wire without text into the 2 terminal.
  9. Wacker Concrete Vibrator M1500120  REV 100 2016 Switch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only the switch remains.
Carsten Frauenheim
145,310 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,460crwdne2935297:0
crwdns2942667:0crwdne2942667:0 311
