Wacker Concrete Vibrator M1500120 REV 100 2016 Power Cable Replacement
  1. Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Disconnect the flex shaft: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Disconnect the flex shaft: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Disconnect the flex shaft: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting, ensure the device is unplugged from power.
    • Pull up on the quick-disconnect handle to release the lock on the flex shaft.
    • Remove the flex shaft.
  2. Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Remove the housing screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T20 Torx screwdriver to remove the nineteen screws securing the two halves of the device housing.
  3. Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Remove the dust filter: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Remove the dust filter: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the device down onto its right side, screw holes facing up.
    • Remove the rear dust filter.
  4. Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Separate the halves: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Separate the halves: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Separate the halves: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift to remove the left half of the device housing.
    • If the housings feel stuck together, use a flathead screwdriver to create a gap between the halves.
  5. Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Lift up the switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Lift up the switch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the switch out of its recess in the case housing.
  6. Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Disconnect the power wires: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Disconnect the power wires: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Disconnect the power wires: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of needle nose pliers to disconnect the black and white power wires from their terminals on the switch.
  7. Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Remove the power cable clamp: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T20 Torx screwdriver to remove the two screws securing the power cable clamp to the housing.
  8. Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the power cable clamp.
  9. Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Remove the power cable assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Remove the power cable assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the power cable assembly up and away from the device.
  10. Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Remove the reinforcing sleeve: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Remove the reinforcing sleeve: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement, Remove the reinforcing sleeve: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the reinforcing sleeve up and off of the power cable.
  11. Wacker Concrete Vibrator M1500120  REV 100 2016 Power Cable Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only the power cable remains.
Carsten Frauenheim
145 512 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 602crwdne2935297:0
crwdns2942667:0crwdne2942667:0 429
