If you need to replace a Brad Nailer Male Air Compressor Adapter Gasket, follow the steps outlined in this guide. For this guide, you will need a crescent wrench and flathead screwdriver. The steps outlined are relatively easy to follow.
Using a crescent wrench, loosen the yellow nut located between the grip and the male air compressor adapter.
Use a spudger to pry the gasket from the base of the threads.
crwdns2935219:0crwdne2935219:0
