This guide will cover how to remove and then replace the battery of a Venture Vulcan II laptop.
Use a J00 screwdriver to unscrew the 10 back-plate screws.
Gently separate the back panel from the laptop.
Use a J00 screwdriver to unscrew the 4 battery screws .
Remove the black adhesive strip covering the battery connector.
Gently remove the battery connector by slowly applying pressure on the connector in the direction of the battery.
