Vtech Move and Crawl Ball Power Switch Replacement
  1. Vtech Move and Crawl Ball Power Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech Move and Crawl Ball Power Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two screws that require a 4.0mm flat head screwdriver. Twist them counter clockwise to remove. When you remove them they stay contained within the blue outer case.
  2. Vtech Move and Crawl Ball Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vtech Move and Crawl Ball Power Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vtech Move and Crawl Ball Power Switch Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the batteries out with your finger. When you replace them be sure to orient them correctly according to the markings in the slots. Match the plus symbol on the battery to the plus symbol in the slot.
  3. Vtech Move and Crawl Ball Power Switch Replacement, Motor: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vtech Move and Crawl Ball Power Switch Replacement, Motor: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vtech Move and Crawl Ball Power Switch Replacement, Motor: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 6 screws in order to pop off the outer shell and reach the inside components.
  4. Vtech Move and Crawl Ball Power Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vtech Move and Crawl Ball Power Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vtech Move and Crawl Ball Power Switch Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the motor by lifting it out of the shell, and find the attached wires at both ends: the circuit board and the motor itself. Use the soldering iron to remove the existing attachments by heating the solder joint with the solder iron tip while pulling on the wire.
    • Make sure the motor is aligned over the correct holes during reassembly.
  5. Vtech Move and Crawl Ball Power Switch Replacement, Power Switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two screws to the power switch located beside the circuit board
  6. Vtech Move and Crawl Ball Power Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vtech Move and Crawl Ball Power Switch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vtech Move and Crawl Ball Power Switch Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the existing attachments at both ends of the wires with the soldering iron. Heat the solder joint with the solder iron tip and pull the wire.
William Jones
crwdns2935283:009/04/15crwdne2935283:0
222 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-1, Sullivan Fall 2015 crwdns2935289:0USF Tampa, Team 2-1, Sullivan Fall 2015crwdne2935289:0
USFT-SULLIVAN-F15S2G1
crwdns2942667:0crwdne2942667:0 910
