Vtech Kidizoom Smart Watch DX Buttons Replacement
Mohammed Alyaarubi
crwdns2944107:0crwdnd2944107:0Mohammed Alyaarubicrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 7, 2024crwdne2944111:0
20 - 25 crwdns2931279:0crwdne2931279:0
crwdns2937803:0crwdne2937803:0
crwdns2942287:0crwdne2942287:0
If the buttons are not working properly, this guide will help you replace them. Note: This guide requires soldering.
crwdns2944105:0crwdne2944105:0
  1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Master Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
    can you add some infomaton on what kids can do to fix it
    Kehinde Abiodun - crwdns2934203:0crwdne2934203:0
  2. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
    I can't get the last two screws off!
    Grant Garbe - crwdns2934203:0crwdne2934203:0
  3. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the master switch from the circuit board.
    But then how to replace master switch? Where does a new one come from?
    Andrea Schiefer (djpurity) - crwdns2934203:0crwdne2934203:0
  5. Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
    For the DX2, the construction appears to have changed, the faceplate is held on with glue and has to be removed from the front. I used an iFixit Opening Tool to do so. Sadly pushing on the screen does not remove it. There is also an internal screw, however I'm unsure if that needs to be removed or not as I had already removed it before attempting to remove the screen.
    Ross Pavitt - crwdns2934203:0crwdne2934203:0
  6. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Buttons Replacement, Buttons: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the the tweezers to pull off the blue rubber cover behind the button.
    • The blue cover is adhesive, so you can stick it back onto the back of the buttons after replacement.
  11. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to separate the backside tab from the front side of the button.
  12. Vtech Kidizoom Smart Watch DX Buttons Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the other half of the button out of the casing.
    • Repeat steps 11 and 12 for all buttons.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Mohammed Alyaarubi
crwdns2935283:001/20/16crwdne2935283:0
365 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-6, Remmell Spring 2016 crwdns2935289:0USF Tampa, Team 10-6, Remmell Spring 2016crwdne2935289:0
USFT-REMMELL-S16S10G6
Where can you buy the replacement cover?
Katrina Nullatamby - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,987
