Battery dead, or not holding a charge? Follow this guide to replace it with a new one! Note: This guide requires soldering.
Flip the watch over with the back facing up.
Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
Gently pull the back plate from the watch casing.
Lift the master switch from the circuit board.
My smart watch repair
My smart watch repaired
Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
De-solder the black speaker wire from the circuit board.
De-solder the red speaker wire, as in the previous step.
Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
Using the plastic opening tool, gently pry the edges of the battery away from from the circuit board.
De-solder the red battery wire from the circuit board.
Repeat the de-soldering for the black (ground) wire.
Pull the battery free, and wait for the solder to cool before handling further.
Where did you bought the battery?
can you add some infomaton on what kids can do to fix it
Kehinde Abiodun - crwdns2934203:0crwdne2934203:0
