Vtech Kidizoom Smart Watch DX Battery Replacement
  1. Vtech Kidizoom Smart Watch DX Battery Replacement, Master Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
    • Flip the watch over with the back facing up.
    can you add some infomaton on what kids can do to fix it
    Kehinde Abiodun - crwdns2934203:0crwdne2934203:0
  2. Vtech Kidizoom Smart Watch DX Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
    I can't get the last two screws off!
    Grant Garbe - crwdns2934203:0crwdne2934203:0
  3. Vtech Kidizoom Smart Watch DX Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the back plate from the watch casing.
  4. Vtech Kidizoom Smart Watch DX Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech Kidizoom Smart Watch DX Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the master switch from the circuit board.
  5. Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech Kidizoom Smart Watch DX Battery Replacement, Circuit Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
    • Removal of the circuit board requires soldering.
    • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
  6. Vtech Kidizoom Smart Watch DX Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
  7. Vtech Kidizoom Smart Watch DX Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
    • De-solder the black speaker wire from the circuit board.
  8. Vtech Kidizoom Smart Watch DX Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • De-solder the red speaker wire, as in the previous step.
  9. Vtech Kidizoom Smart Watch DX Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
  10. Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech Kidizoom Smart Watch DX Battery Replacement, Battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, gently pry the edges of the battery away from from the circuit board.
    • There is a thin layer of adhesive holding the battery to the circuit board. This will remain sticky after prying.
  11. Vtech Kidizoom Smart Watch DX Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • De-solder the red battery wire from the circuit board.
  12. Vtech Kidizoom Smart Watch DX Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the de-soldering for the black (ground) wire.
  13. Vtech Kidizoom Smart Watch DX Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery free, and wait for the solder to cool before handling further.
Navin Ramkishun
crwdns2935283:001/20/16crwdne2935283:0
259 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-6, Remmell Spring 2016 crwdns2935289:0USF Tampa, Team 10-6, Remmell Spring 2016crwdne2935289:0
USFT-REMMELL-S16S10G6
Where did you bought the battery?
funkysoulbrother - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,462
