A faulty speaker can often lead to distorted audio or even no audio at all. This guide is designed to show how to correctly replace the speaker for your drum set in order to restore sound and proper function.
Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
Using your fingers, pry open and remove the back battery panel.
Use your fingers to remove each battery from its housing.
Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
With your hands, separate the bottom panel from the drum set.
Loosen and remove the two 10mm screws using a Phillips #00 screwdriver.
Using your hand, gently remove speaker from its housing.
Using a soldering station, carefully desolder the connection points on the speaker.
