Vtech Kidibeats Drum Set Green Cymbal Replacement
  1. Vtech Kidibeats Drum Set Green Cymbal Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to remove each battery from its housing.
  5. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
  6. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your hands, separate the bottom panel from the drum set.
    • When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
  7. Vtech Kidibeats Drum Set Green Cymbal Replacement, Green Cymbal: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use Phillips #2 screwdriver to loosen and remove the single 16 mm screw.
  8. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, remove the blue cymbal stand from the orange base.
  9. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen and remove the two 14 mm screws using a Phillips #2 screwdriver.
  10. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, separate the two halves of the blue cymbal stand.
  11. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, separate the green cymbal from the blue cymbal base.
  12. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #00 screwdriver, loosen and remove the three 12 mm screws located on the bottom of the green cymbal.
  13. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, separate the green cymbal from the green cymbal base.
  14. Vtech Kidibeats Drum Set Green Cymbal Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, pull apart the green cymbal from the yellow light casing.
Aaron Klementowski
crwdns2935283:002/09/16crwdne2935283:0
820 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-8, Cagle Spring 2016 crwdns2935289:0USF Tampa, Team 2-8, Cagle Spring 2016crwdne2935289:0
USFT-CAGLE-S16S2G8
crwdns2942667:0crwdne2942667:0 757
