Vtech Kidibeats Drum Set Battery Replacement
  1. Vtech Kidibeats Drum Set Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to remove each battery from its housing.
    • When inserting the new batteries, remember to match them according to the image displayed on the battery panel.
Aaron Klementowski
crwdns2935283:002/09/16crwdne2935283:0
820 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-8, Cagle Spring 2016 crwdns2935289:0USF Tampa, Team 2-8, Cagle Spring 2016crwdne2935289:0
USFT-CAGLE-S16S2G8
crwdns2942667:0crwdne2942667:0 1,152
