Vtech InnoTab 3S Screen Replacement
  1. Vtech InnoTab 3S Screen Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Screen Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Screen Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech InnoTab 3S Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Screen Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech InnoTab 3S Screen Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
    • Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
    • Remove the six 3 mm screws securing the battery clip.
  6. Vtech InnoTab 3S Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tweezers, remove one battery clip from each corner (four total) of the Vtech InnoTab 3s.
    • With the tweezers, unsecure the charging port, headphone port, and the light switch button from the front panel of the device.
    • Potential for device damage: Avoid forceful movements when removing the motherboard to prevent damage of device components.
  7. Vtech InnoTab 3S Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vtech InnoTab 3S Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the clip holding the screen plug with the yellow film.
    • The clip securing the screen is located at the top of the motherboard.
    • Remove all seven of the 5mm screws on the motherboard to separate the motherboard from the screen.
  8. Vtech InnoTab 3S Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vtech InnoTab 3S Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Avoid forceful movements when separating the screen from the motherboard.
    • Carefully separate the motherboard from the device screen. Replace the damaged screen with an operational one.
Karina Garcia
crwdns2935283:008/30/15crwdne2935283:0
878 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-2, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 8-2, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S8G2
What is the part number for the screen. Where can I buy one. Thank you.
david goodwin - crwdns2934203:0crwdne2934203:0
My grandson dropped his innotab 3 and now the screen is all scrambled. Can this be fixed? It did not crack the screen.
charma1963 - crwdns2934203:0crwdne2934203:0
Where can I buy the replacement screen for the Vtech innotab 3S
Michael Kurrus - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,403
