In order to repair the Vtech InnoTab 3s, it's necessary to know how to properly take apart the rear panel of the device.
The standard battery options for the InnoTab 3S is four AA batteries. Vtech also offers a rechargeable battery online. Both battery options are removed from the device in the same way.
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
Using a nylon spudger, remove the five caps that hide the screws.
Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
Carefully remove the rear panel from the front panel of the device.
too dumb i tryed 7 times it didnt work i reat this 1000000-/10
