Is the camera not working properly on your child's tablet? This guide will walk you through replacing the camera on the Vtech InnoTab 3S.
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
Using a nylon spudger, remove the five caps that hide the screws.
Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
Carefully remove the rear panel from the front panel of the device.
Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
Remove the camera and the connecting wire from the the clip and attach the replacement cameras connection to the latch on the motherboard.
Carefully lower the latch until you hear a click to secure the new camera to the device.
Hi, we wish to do this but cannot find a replacement anywhere
Where do you get the replacement camera? I can't find them online.
I just did this whole thing...hoping it was a reset to the camera or something, but no, you need a replacement camera. Might be helpful to add that to the PARTS NEEDED part at the top, instead of saying "no parts required." UUGHHHH!
Where can i buy the camera?
kind of useless to post a replacement guide without suggesting a source for that replacement!!
