crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Vornado Flippi V6crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Vornado Flippi V6 Teardown, Removing the base of fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Under the base of the fan, remove the four rubber slip guards by peeling them off with your finger tips.
  2. Vornado Flippi V6 Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the four 2mm screws underneath the slip guards.
  3. Vornado Flippi V6 Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vornado Flippi V6 Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the base of the fan, remove the two screws located under the adjustable speed switch.
  4. Vornado Flippi V6 Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4mm screw next to the adjustable speed switch.
  5. Vornado Flippi V6 Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using one hand, pull out the other half of the base.
  6. Vornado Flippi V6 Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2mm screws.
  7. Vornado Flippi V6 Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull out the bottom cover.
  8. Vornado Flippi V6 Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vornado Flippi V6 Teardown: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using two hands, pull the sides out carefully. You will hear a "pop" noise, indicating the sides have came out.
  9. Vornado Flippi V6 Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan cover using two hands.
  10. Vornado Flippi V6 Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2mm screws holding the blades.
  11. Vornado Flippi V6 Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vornado Flippi V6 Teardown: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the adjustable speed switch cover, slightly pry off 6 clips located around the switch.
Johnny Tran
crwdns2935283:010/21/13crwdne2935283:0
311 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-28, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 4-28, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S4G28
crwdns2947412:011crwdne2947412:0
Thank-you.
I’ve got a flippi V8 and just on a whim decided to save myself some time for tearing it down.
Dan - crwdns2934203:0crwdne2934203:0
In step 10, those screws hold the motor. The fan blades just slide on and off.
This is for the Flippi v6, but the is the same for the v8. The only difference it’s that there are 2 more screws in step 4 for the turning mechanism.
matthew - crwdns2934203:0crwdne2934203:0
Importantly several of the parts have a specific difference between left and right. The cradle and the fan housing itself have a small and a large “bearing” for setting fan angle. The logo goes down. If they don’t match the cradle you cannot reassemble the fan. I took mine apart because the fan bearings needed oil.
fredkrughoff - crwdns2934203:0crwdne2934203:0
What kind of oil and where exactly do you apply it? I have a couple of these that are getting noisey
Aaron -
I would also like to know what kind of oil and where exactly to apply it? One of mine is squeaking loud enough that I haven't been using it. Taking it apart for a thorough cleaning did not do the trick.
Thanks!
Vicki Hogan - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 174
crwdns2942667:0crwdne2942667:0 11,015
