A dirty grill may impede air flow and fan functionality, and a bent or damaged grill may impact the fan blades themselves. This guide will show you how to remove the front grill cover for cleaning or replacement.
            Use a #1 Phillips screwdriver to remove the four 3mm screws.
            Once the screws are removed, turn the fan back over. Use your hands to pull the front grill cover off.
