This will guide you through the process of changing the Xenon lightbulb on your 2016 V60
After opening the bonnet/hood, pull out these two pins, this will release the entire front light and let you pull it out
Once you have pulled the light out, let it rest against your leg or have someone hold it while you disconnect the single power cable by pressing down on the marked tab and wiggling the connector until it come loose
Bring the entire light inside or to your workbench.
Make sure it's clean and dry. If you get any moisture inside the light it may cause issues with the electronics once the seal is broken
Use a T5 bit to remove these 4 screws
Once the screws are removed, gently pull the lid off
Once the lid is off, check the edges of it to make sure that the gasket/seal is not damaged or cracked.
This gasket/seal secure the sensitive electronics inside the light from any moisture
Press the tab gently and use two fingers to gently wiggle the connector while pulling it backwards until it come loose
Push the black tab firmly in the direction of the arrow
Pull the light straight out, using a bit of gentle force
The light is clamped in place by the small tabs, dont touch them and just keep pulling straight out until it comes loose by itself
You should now have a whole Xenon light in your hand.
Second image is a comparison of the old broken light (left and the new light (Right)
Push the new light straight in until it is seated firmly in the tabs
Be very careful to not touch the glass of the bulb as that will leave oil residue from your fingers. Any amount of contact with your skin may (Read: It will) dramatically reduce the lifespan of your lightbulb
Reconnect the powercable to the light by pushing until you hear a soft click
Replace the lid to the lights and retighten it with the 4 screws.
Use a T5 bit for the screws
Reconnect the single power cable to the light
Press firmly until you hear a click
Reseat the light into the car by aligning the light with the guide hole
Replace the two pins to resecure the whole light to the car
The long pin should be placed in the outer hole, while the shorter pin goes on the inner hole
Ensure that the metal tabs are pointing inwards
Restart the car
Your light should now work again!
The manual has multiple warnings stating that the Xenon light should only be replaced by a professional technician. But it is infact very easy to do it yourself
