Voluas VL001 Motor Assembly Gears Replacement
  1. Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement, Storage Tank: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lid to the storage tank by using the latch and lifting off.
    • Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
  2. Voluas VL001 Motor Assembly Gears Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement, Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your pet feeder upside down.
    • Squeeze the lock and remove the battery cover.
    • Remove the three 1.5V D alkaline batteries.
  3. Voluas VL001 Motor Assembly Gears Replacement, Housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement, Housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement, Housing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a metal spudger under the adhesive part of each rubber foot.
    • Pry the foot off.
  4. Voluas VL001 Motor Assembly Gears Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four screws from the corners of the device using a Phillips #2 screwdriver.
    • These holes were previously covered by the rubber feet.
    • Using the magnetic tip of the screwdriver, carefully lift the screw out of the hole.
  5. Voluas VL001 Motor Assembly Gears Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over so it is oriented right-side up.
    • Lift the top part of the feeder off, exposing the mechanisms that run the feeder.
  6. Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement, Motor Assembly Gears: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the six screws that hold the motor housing on to the device.
  7. Voluas VL001 Motor Assembly Gears Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the electric motor from its housing and move it aside.
  8. Voluas VL001 Motor Assembly Gears Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to remove the first gear that is placed on top.
  9. Voluas VL001 Motor Assembly Gears Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to gently remove the second gear.
  10. Voluas VL001 Motor Assembly Gears Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Voluas VL001 Motor Assembly Gears Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to gently remove the third gear.
Jade Thomson
crwdns2935283:001/30/24crwdne2935283:0
699 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-3, McMurrin Spring 2024 crwdns2935289:0Utah Tech University, Team 1-3, McMurrin Spring 2024crwdne2935289:0
UTAHTECH-MCMURRIN-S24S1G3
crwdns2942667:0crwdne2942667:0 107
