Device model: Volisun 4-inch recessed LED light.
What this guide does: Replace a burned or degraded 4-inch VOLISUN recessed LED light. By completing the steps of the guide, you will have a new working LED light.
About the part: The LED connects to a small driver box(power box) that is above the ceiling. This guide only replaces the LED light.
When to use the guide: Use the guide when the LED light won't turn on or is physically damaged. If you have a similar light, make sure it's LED-compatible before replacing.
Find where the clips are for your LED light by pulling carefully.
Carefully pull down from one side where the clip is.
Press down the clip to not damage part of the ceiling.
Pull towards you so the other clips comes out.
Twist the cap counterclockwise.
Pull the cap up.
Disconnect the LED connector from the driver connection.
Replace the old LED light with a new one.
Attach the new LED light connector to the driver connection.
Put the cap back.
Twist in a clockwise direction.
Push both sides of the clips towards the middle.
Push up until the clips are inside the hole.
Push until it's flush with the ceiling.
Turn the breaker back on, flip the switch, and test the fixture.
