Vizio VTAB1008 Charging Port Replacement
  1. Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement, Vizio VTAB1008 Back Cover Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Charging Port Replacement, Charging Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement, Charging Port: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement, Charging Port: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the motherboard by unscrewing the four securing screws with a J1 Phillip's head screwdriver.
    • 3 of the screws are clearly visible while the 4th is hidden by black tape on the upper left corner of the motherboard.
  4. Vizio VTAB1008 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove both antenna connectors with a blue opening tool/tweezers.
  5. Vizio VTAB1008 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ribbon connector at the top of the motherboard using the opening tool.
  6. Vizio VTAB1008 Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the connector at the top of the motherboard by pulling the connector away from the motherboard with fingers or tweezers.
  7. Vizio VTAB1008 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the connector at the side of the motherboard using the opening tool.
    • The connector is covered by a piece of black tape.
  8. Vizio VTAB1008 Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the red and black wire connector from the motherboard using either fingers or tweezers.
  9. Vizio VTAB1008 Charging Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vizio VTAB1008 Charging Port Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the motherboard over.
    • Directly underneath the USB Charging connector will be four solder points that need to be undone in order to remove the charging port.
Gilberto Ambriz
crwdns2935283:009/29/16crwdne2935283:0
546 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-1, Crane Fall 2016 crwdns2935289:0Eastern Washington University, Team 1-1, Crane Fall 2016crwdne2935289:0
EWU-CRANE-F16S1G1
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,337
