Hello! This guide will show you how to replace the battery in a Vizio VTAB1008.
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Look into the tablet for loose connectors.
Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
Remove the ribbon strip that crosses the battery from both ends.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the connector at the top of the motherboard by pulling out and away from the motherboard.
Pull the battery away from the back panel.
