Vizio E422VA Mainboard Replacement
  1. Vizio E422VA Mainboard Replacement, Unscrew Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Philips #2 screws, 15.0 mm
    • Philips #2 screws, 29.5 mm
    • Philips #2 screws, 8.0 mm
    • VESA mount points (M6, 10mm, 400mm * 200mm)
  2. Vizio E422VA Mainboard Replacement, Remove Rear Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After all screws removed, the rear plastic cover can be lifted off.
  3. Vizio E422VA Mainboard Replacement, Internal View: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Mainboard
    • Power Supply / Backlight Inverter
    • Timing Control (T-Con) Board
  4. Vizio E422VA Mainboard Replacement, Remove Connectors from Mainboard (Part 1): crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 4-pin connector to T-Con board. Depress plastic clip at left side and wiggle connector side to side slightly to remove.
    • 13-pin connector to Power Supply board. depress plastic clip at left edge and wiggle connector side to side. May need to pry up top/bottom edge with flat head screwdriver; alternate gradually.
    • 42-pin connector. Pry up with flat head screwdriver on left/right edges, alternating gradually.
    • Grounding clip. Using a poking tool, press at center to release catch and pull clip in indicated direction.
  5. Vizio E422VA Mainboard Replacement, Remove Connectors from Mainboard (Part 2): crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 8-pin connector. Depress clip and pull connector upwards from board.
    • 10-pin connector. Depress clip and pull connector upwards from board.
    • 4-pin connector to speakers. Depress Clip and pull connector in indicated direction.
    • mounting screw. Philips #2 @ 6mm
  6. Vizio E422VA Mainboard Replacement, Removing I/O Shield on Bottom Edge (optional): crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If your replacement board is missing the bottom I/O shield, you can remove the I/O shield from the old board by removing the marked screw (Philips #2).
MrBadAxe
crwdns2935283:002/06/24crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 102
