Using this guide, you will be able to remove a broken battery from the Vizio CT15 in order to replace it with a new one.
Turn the laptop off and remove all power cables.
Remove the six Phillips #0 screws.
Pull the back cover off.
Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
In case anyone comes across this page looking for the CMOS Battery, it is an ML1220 Battery. I found a comparable replacement of "LeFix ML1220 Rechargeable CMOS Battery Replacement Compatible with ASUS EEE PC 1101HA 1005HA T101MT 1101HAB 1005P,Acer Aspire 5920 5920G 5920 G Series,Fujitsu Amilo Pi 3560 3660 LI3710 LI3910" on Amazon (https://www.amazon.com/LeFix-Rechargeabl...)
tech2life - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
