Vixen 21 Oil Cooler Replacement
  1. Vixen 21 Oil Cooler Replacement, Oil Cooler: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the side panel, it's clear that my oil cooler has been leaking for a while. Fortunately, AFAB sells a complete replacement kit including a new oil cooler and new hoses!
  2. Vixen 21 Oil Cooler Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The tail light covers come off easy enough with 10 screws and a single connector.
    • The white housing beneath comes off with a bolt on the left and a screw on the right.
  3. Vixen 21 Oil Cooler Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On my Vixen there was a hex head bolt on the top right, and a on-its-way-to-being-stripped Phillips head bolt on the top left.
  4. Vixen 21 Oil Cooler Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There were two Phillips screws in the bottom of the panel, but these weren't actually attached to anything.
    • My new side-routed exhaust definitely made it harder to get this panel out.
  5. Vixen 21 Oil Cooler Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There's one electrical plug and 4 obvious hex bolts to remove the condenser fan.
  6. Vixen 21 Oil Cooler Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the condenser fan is removed we can get a good look at the oil cooler. The fittings are certainly leaking, but the cooler itself might actually be fine.
    • The Vixen bleeds black and I bleed red, whoops!
  7. Vixen 21 Oil Cooler Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here's all the shiny new replacement parts. You can buy the oil cooler kit from AFAB.
    • I made a mess of the threads putting one of the blue aluminum fittings in to the top of the new oil cooler. Thanks to a 1/2" NPT tap and die from Harbor Freight and a friend's help I was able to salvage it and I don't think it leaks, but time will tell...
  8. Vixen 21 Oil Cooler Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On a closer inspection, all my existing fittings are leaking, which at this point I suppose is a good sign.
  9. Vixen 21 Oil Cooler Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Getting the oil cooler off the condenser was easy, there's just two bolts. But it's still attached to the engine...
  10. Vixen 21 Oil Cooler Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • It was easy enough to loosen the hose clamps and pop the hoses off.
    • This made a mess, because not surprisingly, there's oil in the lines.
  11. Vixen 21 Oil Cooler Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The old oil cooler is out!
  12. Vixen 21 Oil Cooler Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There was a lot of oil/dust sludge beneath the oil cooler, requiring a rather dirty cleanup.
  13. Vixen 21 Oil Cooler Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the remaining couplers was quite challenging.
    • I was able to borrow some large metric wrenches (24 mm and 27 mm) from a friend to help with this step.
  14. Vixen 21 Oil Cooler Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the first fitting was off, I was able to get a 24 mm socket over the second one to remove the fitting.
  15. Vixen 21 Oil Cooler Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • I routed the new lines the same as the old ones.
    • The plastic lining the hole the hoses go through is definitely decaying, but seems like it'll still protect the hoses ok.
  16. Vixen 21 Oil Cooler Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The lines are just barely long enough, but it reaches!
  17. Vixen 21 Oil Cooler Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Mounting to the condenser is straightforward.
  18. Vixen 21 Oil Cooler Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vixen 21 Oil Cooler Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Everything's in place!
    • I spent some more time cleaning the dirty panel below. Thus far I have no leaks from the new oil cooler!
Staff
crwdns2935297:023,267crwdne2935297:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 1,763
