Press down on the side button, and lift up the top dome.
Remove three screws that connect the camera base to the motherboard using a Phillips #1 screwdriver.
Lift off the camera base from the motherboard.
Unscrew the cord from the motherboard.
Unplug the remaining connection.
Unscrew the camera from the camera base with a hex screwdriver on both sides.
Pull the camera out from the camera base.
Once the camera module is removed, unscrew the two remaining screws which attach the motherboard to the backplate.
Once the screws are gone, lift the faulty motherboard and replace with a new one.
