Vivitar DVR 781HD Motherboard Replacement
  1. Vivitar DVR 781HD Motherboard Replacement, Front Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vivitar DVR 781HD Motherboard Replacement, Front Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vivitar DVR 781HD Motherboard Replacement, Front Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vivitar DVR 781HD Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vivitar DVR 781HD Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
  4. Vivitar DVR 781HD Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Vivitar DVR 781HD Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
  5. Vivitar DVR 781HD Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the motherboard, handling it by the edges.
Nathan McDaniel
crwdns2935283:002/13/16crwdne2935283:0
592 crwdns2915208:0crwdne2915208:0
IUPUI, Team 54-6, Wilson Spring 2016 crwdns2935289:0IUPUI, Team 54-6, Wilson Spring 2016crwdne2935289:0
IUPUI-WILSON-S16S54G6
crwdns2935297:013crwdne2935297:0
It says no parts required, but it is instructions to replace the motherboard.
There is nothing about getting another motherboard, and how much.
Heki Kahni - crwdns2934203:0crwdne2934203:0
How do you get a motherboard?
Rdam Russell - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 1,521
