Vivedino Raptor 2 Hot End Removal
  1. Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure all power cables to your 3D Printer are unplugged including wall plugs (A/C) and/or USB cables.
    • Remove the Print Head Assembly and move to a well lighted clean area.
    • Retain all parts and hardware for reassembly!
    • Use a #1 Phillips Screwdriver and remove the name plate.
    • DO NOT remove the hot end fan screws
    • Using a #1 Phillips and M2.5 hex, remove the screws securing the part cooler fan.
    • For the socket head screw, go to the next step.
  2. Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the nut with needle nose pliers and remove the socket head screw and nut.
    • The final screw holding the part cooler duct on is accessed from underneath. Use a #1 phillips for this.
  3. Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the part cooler fan.
    • Unplug the hot end fan.
    • Remove the hot end fan and holder. Grab the fan with your thumb and index finger and pull it 180 degrees from the opening.
    • Using a small flat tip screw driver, loosen the phoenix connector to release the heater wires.
    • Unplug the thermistor connection.
    • Remove the bottom 2 motor screws.
    • Remove the 2 upper motor screws. They also hold the lever in place, which is under spring tension.
    • Squeeze the lever down while removing or installing the upper 2 to help align the holes.
  4. Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Vivedino Raptor 2 Hot End Removal, Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the 4 socket head cap screws with M2.5 hex until the horseshoe is loose.
    • Remove the horsehoe.
    • The hot end can now be removed by pulling it down and out of the printed body.
    • If it is stubborn, you can gently pry between the top fin and printed mount with a flat screwdriver.
  5. Vivedino Raptor 2 Hot End Removal, Measure and Rebuild: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now is the time to repair or replace your hot end.
    • Important Reminder: If you change any components, note the length of a few things...
    • The protrusion of ptfe tubing out the top.
    • The length of the hot end. Any change here will affect Probe Z Offset and may cause issues if too long or too short.
crwdns2935103:0crwdne2935103:0
Tiny Machines 3D
crwdns2935283:011/16/19crwdne2935283:0
3,019 crwdns2915208:0crwdne2915208:0
Tiny Machines 3D crwdns2935289:0Tiny Machines 3Dcrwdne2935289:0
Community
crwdns2935297:041crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 989
