Visual Land Prestige Pro 7D Speaker Replacement
  1. Visual Land Prestige Pro 7D Speaker Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
  2. Visual Land Prestige Pro 7D Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
  3. Visual Land Prestige Pro 7D Speaker Replacement, Speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the speaker off of the back panel.
  4. Visual Land Prestige Pro 7D Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Visual Land Prestige Pro 7D Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Soldering guns are hot and can easily damage the device.
    • Desolder the two connection points at the black and red wires.
    • A helpful guide for desoldering can be found here How To Solder and Desolder Connections.
Jennifer Laybourn
crwdns2935283:010/14/14crwdne2935283:0
353 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-41, Amido Fall 2014 crwdns2935289:0Cal Poly, Team 10-41, Amido Fall 2014crwdne2935289:0
CPSU-AMIDO-F14S10G41
crwdns2942667:0crwdne2942667:0 694
