Complete the following guide to replace a broken LCD screen on your tablet.
At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
Wedge a plastic opening tool into the edges of the tablet to pry it open.
Wedge a curved metal spudger to remove the speaker.
Use a Phillips #000 screwdriver to remove the two 3.6mm screws.
Use a plastic opening tool to lift the black tab.
Carefully remove the ribbon cable from the black tab.
Use a plastic opening tool to remove the camera.
Use a Phillips #000 screwdriver to remove the 3.6mm screw.
Lift the tape holding down the battery.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Wedge a plastic card underneath the battery to remove it.
Lift to remove the battery and motherboard from the tablet.
Use a Phillips #000 screwdriver to remove the three 2.5mm screws.
Wedge a metal spudger underneath the LCD to remove it.
Replace the LCD.
