Complete the following guide to replace your tablet's front camera.
At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
Wedge a plastic opening tool into the edges of the tablet to pry it open.
Use a plastic opening tool to lift the black tab holding down the ribbon cable.
Carefully use your finger to pull out the ribbon cable.
Use a plastic opening tool to pull out the camera with the foam backing.
Remove the camera from the foam backing.
Replace the camera.
