Visual Land Prestige 10 Digitizer Replacement
crwdns2944105:0crwdne2944105:0
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
Using the spudger, create a small opening to be used to open the back case.
While holding the case open, insert the plastic opening tool to get a larger opening.
Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
now that the case is open, carefully remove the speakers and set aside.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Gently remove the speakers from the back case with tweezers and set the case aside.
Remove yellow tape from surrounding components.
insert the spudger and gently work around and underneath the battery.
With the battery separated from the LCD Display, set it aside.
Desolder and remove the 2 wires from the motherboard.
How do i get a new battery
How do i get another
go to Amazon and order a Prestige Prime 10SE tablet
How do i order another
go to Amazon and order an Prestige Prime 10SE tablet
your tutorial worked but my tablet is a little different but it has the same model id
Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
Gently grip and pull up the front camera, covered by protective adhesive foam.
Set aside the Camera housing.
Locate the LCD Connector.
Using tweezers, grip the small black tab connected to the white plastic.
Gently lift the tab towards you until it clicks.
Remove the connector by pulling straight out, gripping the black connector head.
Locate the Touchscreen connector and grip the forward-most black tab with the tweezers.
Lift the tab towards you until you feel an audible click.
Gently remove the connector by pulling straight out, gripping the black connector head.
Gently lift up the WiFi antenna and set aside.
Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them.
Gently lift up on the controller and leave it hanging loose.
Remove screws located on motherboard.
Place on magnetic mat and label them
Gently remove the Motherboard and any wires connected to it and set it aside on a static free surface.
Remove the screws and plastic tabs holding the LCD Display and place them on the magnetic mat. Label them.
Gently remove the LCD Display and backlight by lifting up the LCD Connector with your fingers.
Set aside the LCD Assembly.
Simply lift up the loose metal frame and set aside.
Be extremely careful removing the touchscreen, avoiding sharp glass and hot surfaces.
Using the heating pad, heat the edges of the touchscreen to loosen the adhesive.
using the spudger, slowly and gently work around the edges, removing the touchscreen.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947410:01crwdne2947410:0
Great write up, but have a question . Could you heat up the adhesive for the digitizer like an iPad and remove it without taking everything apart?
